Error Code P0305..need help ASAP
STEVECARR1979
I know this code means that cylinder 5 is misfiring but how can i fix it?
Would changing the spark plugs help out or do i need to do something else?
Mar 4, 2007 at 5:16 AM
CARUNDELL
  • 602 POSTS
[quote:749b1807f4="stevecarr1979"]I know this code means that cylinder 5 is misfiring but how can i fix it?
Would changing the spark plugs help out or do i need to do something else?[/quote:749b1807f4]
Hey Steve
Please give the year, make, model and engine size and I'll be able to help ya more! Let me know!
Chris
Mar 4, 2007 at 7:05 PM
STEVECARR1979
dodge durango 2004
4.7L engine about 91,000 miles
Mar 4, 2007 at 8:59 PM
DAN V
i know this may sound weird but i would try resetting the comp.or erasing the code because some of the comp. in the newer vechiles are so picky they are actually too picky or should i say the software is . usually if you have a bad plug or spark plug wire you will know it.
Jul 4, 2007 at 7:35 AM
