2001 Dodge Durango Camshaft Code
JASONCL
I own a 2001 Dodge Durango with 98,000 miles on it in which the motor failed. I got a replacement from a salvage yard with 48,000 miles and had it installed but we are having a very hard time getting it to run smoothly. The motor is a 4.7 and we keep getting a cam shaft code like the timing is off. My mechanic says that if the timing is off that he would have to tear the motor down and start over to reset the timing. Is this true?
Feb 26, 2007 at 1:57 AM
2CARPRO JACK
  • 11,533 POSTS
If the engine wasnt taken apart then it wont need to be torn down. The engine needs to be put on #1 TDC to see where the distributor is pointing. The computer is seeing that the cam and crank are out of sync. worst case is the distributor would have to come out to be reinstalled correctly
Feb 26, 2007 at 11:33 PM
Suggested Repair
If the replacement engine was not taken apart, a full teardown is not required. Set the engine to #1 TDC and check where the distributor points, since the computer sees the cam and crank out of sync. Worst case, remove and reinstall the distributor correctly.
Conversation Summary
The owner of a 2001 Dodge Durango had a salvage 4.7 engine installed, but it runs poorly and sets a camshaft timing code. The mechanic said the engine would need to be torn down to reset the timing. The expert said a teardown is unnecessary if the engine was not disassembled; set it to #1 TDC, check distributor position, and reinstall the distributor if needed.
