2006 Dodge Durango wont start
50,000 MILES • V8 • 4WD • MANUAL
KEVIN2
multiple clicking noise while starting used to start after retry now it wont
Oct 15, 2010 at 12:28 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 15, 2010 at 2:10 AM
