2006 Dodge Durango HELP
69,000 MILES • V8 • 4WD • AUTOMATIC
RZULCH82
My engine has no power. It feels very sluggish between shifting gears, and has a very low ideal. I just had the Trany Serviced (replaced fluid and filter) but the problem is still there. The check engine light has come on but went off the next day? can you help me solve this problem
Mar 15, 2010 at 7:06 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 15, 2010 at 3:49 PM
