2005 Dodge Durango Serpentine Belt
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
KANICHOLS
A small kitten got in the engine & the belt came off of all the pulleys (the kitten wasn't injured). The belt was put back on and a new one was purchased & changed a bit later. My car has the automatic tensioner. The belt is installed correctly, however; it now squeeks & squeals. It was squeeking & squealing when the engine was started, now it only does it if the air conditioning or heater is turned on. It eventually quits only to do it again on & off about every 1/4 to 1/2 mile down the road. As long as the air or heat is not on, it doesn't squeek or squeal. Belt dressing was applied and it has not helped.
What might be the cause of this noise? I can't stand it.
Oct 27, 2009 at 7:57 AM
DOCFIXIT
  • 18,828 POSTS
When old belt was back on did it squeal? Did you make sure new belt was correct? compare numbers on old belt to new.
Oct 29, 2009 at 8:18 AM
