HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Durango
Brakes
Caliper
Mount
2005 Dodge Durango Brake caliper torque settings
TMNFINN
MEMBER
2005 DODGE DURANGO
Brakes problem
2005 Dodge Durango V8 Four Wheel Drive Automatic
I am replacing the front brakes on a 2005 Dodge Durango and need to find the torque settings for the caliper mounting bolts and caliper slide bolts.
Thanks
Wednesday, June 16th, 2010 AT 4:11 PM
MECHANIC
Banjo bolts at 250 in lbs and slide pin bolts at 24ft lbs
Thursday, June 17th, 2010 AT 2:23 AM
MECHANIC
130 ft lbs Thanks for the feedback
Thursday, June 17th, 2010 AT 2:46 AM
Please
login
or
register
to post a reply.
Related Caliper Mount Content
1999 Dodge Durango
Brakes Problem 1999 Dodge Durango V8 Automatic I Have A 99 Dodge Durango. I Recently Replaced The Hub, Brake Pads, And Rotors. It...
Asked by
snowpawn
1 ANSWER
1999
DODGE DURANGO
2005 Dodge Durango No Brake Pressure
When The Brake Pedal Is Depressed When The Car Is Off It Gets Tougher After About 2-3 Strokes Then Stays Pretty Tough. When The Car Is...
Asked by
Targetweek
1 ANSWER
2005
DODGE DURANGO
Knocking Noise/feeling In Brake Pedal
I Have The Vehicle Listed Above With Mileage Of 43,000, V8 (non-hemi), Automatic, 4wd. I Bought The Truck New In 2004. Over The Past Few...
Asked by
rbgle00
5 IMAGES
2004
DODGE DURANGO
Rear Turn Signal Stops Flashing When Brake Pedal Is...
Why Does The Left Hand Rear Turn Signal Stop Flashing When I Step On The Brake Pedal?
Asked by
clayhaan
1 ANSWER
1999
DODGE DURANGO
Bleeding Brakes
V8 Four Wheel Drive Automatic I Just Rebuilt My Back Brakes, Drums, Shoes And Wheel Cylinders. The Back Brakes Were Not Working, And...
Asked by
larc
1999
DODGE DURANGO
VIEW MORE
How to Fix a Brake Pull
Brake System Flush
Bleed and Flush Your Brake System Correctly
