2004 Dodge Durango Rotors
DURANGO_04
Brakes problem
2004 Dodge Durango V8 All Wheel Drive Automatic
Can you tell me what size socket it takes to remove the nut holding the front rotors in place?
Jul 4, 2008 at 5:36 AM
MERLIN2021
  • 17,250 POSTS
DO NOT touch that axle nut! All you do is remove the caliper and the mount, then if the spring retainers are on two of the lugs, remove them, they look like flat washers. The rotor then just pulls off, if it's stuck due to rust, hit it with a hammer a few times!
Jul 4, 2008 at 5:42 AM
