2004 Dodge Durango my dodge is not moving at all!!!!
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
COTTONCANDY29
my truck doesnot move. if i put it in drive andpress on the gas it does not move>if i put it in reverse it does not move> what can the problem be?
May 12, 2010 at 11:35 AM
  • 31,937 POSTS
Hi there,
Do you have oil in the transmission? is the box actually selecting gears? try starting with it in gear, you may have a failed oil pump or converter, you will need to check the box line pressures to see if the pump and torque converter are OK.
mark (mhpautos)
May 12, 2010 at 7:29 PM
