2004 Dodge Durango interior lights
2004 DODGE DURANGO
93,000 MILES • V8 • 2WD • AUTOMATIC
DANSLIDELL
  • 5 POSTS
interior lights stay on long period of time and overnight
Mar 21, 2009 at 4:11 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me your engine size in liter and the 8th digit of your VIN.
Also you do have day light running lights?
Does your door ajar light come on or stay on at times.
You do have a delay on your interior lights at night…….when the door closes it delays and then goes off………or use to
Mar 21, 2009 at 4:49 AM
DANSLIDELL
  • 5 POSTS
"To better assist you please tell me your
engine size in liter":
4.7
"and the 8th digit of your VIN": last eight digits are
4F209643
"Also you do have day light running lights?"
no
"Does your door ajar light come on or stay on at times.":
not having any problems with the door ajar light at this time
"You do have a delay on your interior lights at night…….when the door closes it delays and then goes off………or use to" :
Yes there is a delay on the lights normally but currently they just stay on even while driving, I can press the button to turn them off and that will dim them a little but they will not go off, they are even staying on overnight after the the car is turned off.
Mar 21, 2009 at 8:29 AM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the update………….
For the 8th digit of the VIN…….please count from far left to the 8th digit……could be a letter or number………….
For now while I am checking with the info you gave me, take some WD40 and spray all of your door latches. The part on the door that latches around the striker plate on the body. Spray really good, then open close several times, then spray really good then open close. Make sure you get all over that latch assembly as best as possible.
Let me know what happens……..meanwhile……….I am looking………….
Mar 21, 2009 at 9:18 AM
DANSLIDELL
  • 5 POSTS
the eight didit is N I removed a fuse inside on the driver side kick panel and lights have shut down in a dodge ram owners manual it is call a CCN cabin conpartment node
Mar 21, 2009 at 10:35 AM
DANSLIDELL
  • 5 POSTS
it look to be a proble with the instrument cluster
Mar 23, 2009 at 10:31 AM
IMPALASS
  • 3,112 POSTS
Hello –
Sorry so long to get back with you. I had some technical difficulties.
Are you saying you have it fixed now?
Mar 23, 2009 at 3:37 PM
IMPALASS
  • 3,112 POSTS
Hello - By the way, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recalls_21.jpg
Mar 24, 2009 at 2:56 PM
DANSLIDELL
  • 5 POSTS
the instrument cluster was the problem after all my research in was a recall took me day and yet no one sent this recall
Apr 3, 2009 at 12:15 PM
IMPALASS
  • 3,112 POSTS
Hello –
So it was the recall listed above????? Instrument board circuit board capacitor?
So now it is fixed?
Apr 4, 2009 at 3:26 AM
