Heater not working correctly?
86,500 MILES • V8 • 2WD • AUTOMATIC
MAUWILEKA
My front heater is not working but my rear heater is. What is the problem? is it something that I can fix? If so, tell me how.
Dec 17, 2009 at 9:02 AM
CARADIODOC
  • 34,415 POSTS
Is the fan blowing air on all speeds? Is the temperature of the air wrong? Is it blowing out of the wrong ports?
this guide can help
https://www.2carpros.com/articles/car-heater-not-working
Dec 25, 2009 at 5:35 PM
LYNETTEPAGE
we replaced the thermostat four times. Just replaced the water pump. This car has been acting up for a year by overheating. There is no heat in the winter. I understand this type of vehicle has this problem a lot but I can't find anyone who knows what's wrong with it. Mechanics say they flushed it also.
Aug 6, 2020 at 3:55 AM (Merged)
SCGRANTURISMO
  • 4,897 POSTS
Is the heater core bypassed? If it is not then there has to be a restriction in the system somewhere. There is no other explanation for this condition. You might have an air pocket that not allowing the coolant to flow. I have included in the diagrams below a Technical Service Bulletin (TSB) and a description of the cooling system for you. I have also included a few links down below for you to go to.
https://www.2carpros.com/articles/engine-cooling-system
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Please go through these guides and get back to us with what you are able to find out please.
Thanks,
Alex
2CarsPros
ASA7010
My wife's 03 dodge durango doesn't blow hot air for the rear controls. It does blow cold air, I checked the aux water pump and the hoses are warm and the electrical connection is good but still no heat. Can someone help?
Aug 6, 2020 at 3:56 AM (Merged)
TOMSTATION4
All the other forums are talking about this problem. I have the same problem. It is most likely a broken actuator rod on the rear damper door which controls the rear heat. It is located by the passenger side rear heater under the panels there. You will have to disassemble the panels to look at the door and the rod that attaches to it. Apparently everyone is having the problem which is what is usually the case. They say it is expesive to get the part from the dealer but may be cheaper with junkyard parts. Hope that helps. I am going to tear into mine tomorrow and have a look but I am certain that is the problem.
LORI BONDE
We have replace the resistor 3 times along with the blower motor twice. Is this a common problem with this vehicle?
  • 110,248 POSTS
Is the motor going bad or the resister? I've seen motors that draw too much power burn up resisters, but you have replaced everything. The only other thing I can think of is if there is a weak ground. The ground is provided through the switch. Have you checked the switch?
I attached a pic of the ground. Check to make sure it is in good condition. A weak ground can cause excessive heat in the unit.
Let me know what you find
MBALYS2003
about 3months ago the low and medium setting stopped working both air conditioning and heat today the high setting gave out. any ideas?
HMAC300
  • 48,601 POSTS
check your resistor and relay they should be by teh blower motor. see if the resistor is getting power or not, that controls the lower speeds
MBALYS2003
thank you so much. now i won't feel so dumb when speaking to a mechanic.
MARCALB
Hi, my heater gets the cat hot but when you put your hand to the vents it seems like it's not blowing that much. Also, the rear A/C control only blow cold it does not get hot. What is the problem?
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
On the front vents have you checked to see if all the fan speeds work? As far as the rear heater it sounds like you are having a problem with the mode/blend door actuator. Here are two tutorials for you to view for blower motor and blend door actuators to show you what is involved:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Below I've attached a picture of the rear HVAC system and circled in red the actuators location.It's basically an electric motor that controls which ducts the hot or cold air travels.Hope this helps and feel free to ask any questions if needed.Thanks for using 2CarPros.
Danny-
MIKE1098
  • 5 POSTS
front heater wont work on my 2001 dodge durango
  • 75,988 POSTS
Possibilities here could be the front AC/Heater control, blower motor and the blower motor resistor
MIKE1098
  • 5 POSTS
Do you know where the blower motor resistor is located on my 2001 dodge durango?
  • 75,988 POSTS
BLOWER MOTOR RESISTOR BLOCK - FRONT
During vehicle assembly, the blower motor resistor is mounted to the HVAC unit inside the passenger compartment.
BLOWER MOTOR RESISTOR BLOCK - REAR
The blower motor resistor for the optional rear A/C unit is located within the unit housing.
MIKE1098
  • 5 POSTS
front heater wont work on my 2001 dodge durango but the rear heater works fine
Aug 6, 2020 at 3:57 AM (Merged)
  • 110,248 POSTS
Check the heater core hoses to make sure both are hot when the engine is running, hot and the heater is on. If both are hot, check the blend door under the dash near the heater core. If it isn't opening, you won't get heat.
BLOND
The heater in the front seats works great, but in the middle and the back of the vehicle it will only blow cold air. What would cause this?
FRANKIEFUEGO
  • 18 POSTS
I have the same problem so if you find out, let me know. Thanks
TTENN
The front heater will blow warm air after vehicle is warmed up and only on fan speed 1. if you turn it up any higher it blows cold air as if the heater core is not getting hot enough, have recently replaced radiator and headgaskets due to headgaskets blown. Had a shop do this. Also the rear heat does not work it blows outside temp air all the time. Please help me with this situation. Thank you in advance.
  • 110,248 POSTS
Are you sure the coolant is full? Also, with the engine hot, running and the heater on, do both heater core hoses get hot?
IFLYFL340
well mine is also doing this but on speed 2 any higher blows warm then cold the upper heater core hose is hot the lower is warm anyone that can help please with a post or
call me at 918-409-3758 anytime
thanks
nick
  • 110,248 POSTS
It is normal for the return to be a little cooler, but does it feel like the coolant may be taking too long to get through because the core is plugged? If not, have you checked the blend door?
IFLYFL340
good ? where is the blend door at i looked under where the wipers are and there is a big hole for where the fresh air i guess would enter at but i got no clue where the blend air doors is
YOGITBEAR
Has heater in front and one in the rear the rear has only cold air coming out when turned on no heat comes out but front one has heat?
BMRFIXIT
  • 19,053 POSTS
It sounds like the blend door actuator in the rear is not working here is a guide to elp walk you through the repair on a similar car.
