2004 Dodge Durango Engine Wont Start
49,000 MILES • V8 • 4WD • AUTOMATIC
SBMILLER10
The car will start and then will immediatley turn off. You can try this a couple of times and sometimes it will start up fine after a couple of tries and other times it will just turn over and not start at all. This does not happen all the time just on some random tries.
Nov 18, 2009 at 9:00 AM
BMRFIXIT
  • 19,053 POSTS
Few thinks to consider and check
check ignition switch
check for fuel ,check for spark
do you have a security system
check RELAYS ASD and fuel pump relays
Nov 18, 2009 at 9:58 AM
