how do you change an oil pump?where exactly is it located?how much does this cost?
May 18, 2010 at 2:38 AM
✓Experienced Mechanic
The engine oil pump is located inside the oil pan. In your case, you will need to lift the engine to remove the pan and then unbolt the pump. The pump will most likely be around 75.00 based on where you live.
