2004 Dodge Durango
LARYJUM
Electrical problem
2004 Dodge Durango V8 Two Wheel Drive Automatic
Engine continues to run 4 to 6 seconds after you yurn ignition off. If you disconnect 2 wire connector on alternator vehicle turns off normally. I tried a different alternator but did not fix problem.
Feb 20, 2010 at 8:51 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Do instrument gagues stay on also? Radio keep playing?
Let me know
Thanks for donate
Feb 22, 2010 at 6:28 AM
LARYJUM
The dash lights go out when key is turned off. It appears the ignition switch is turning off at least the accessories.
Feb 22, 2010 at 11:30 AM
DOCFIXIT
  • 18,828 POSTS
On fuse # 18 in IP fuse box put test light should light with running. Key off test light stay on for the 4-6 sec?
Feb 23, 2010 at 1:16 AM
