2003 Dodge Durango rear defrost and wiper
79,000 MILES • V8 • 4WD • AUTOMATIC
GAYLE BENINTENDI
My rear wiper and defrost are not working. I have checked the fuses under the hood (could not locate others) but it was not fuses. Any suggestioins? (~)
Jan 29, 2010 at 8:44 AM
MERLIN2021
  • 17,250 POSTS
Gayle the weak spot in any wiring harness is where the wires flex, this is at the top comming out of the body, and going into the rear liftgate, check there for broken wires, it's a common problem. Turn the defroster on and use a test light or voltmeter on the connector on the glass, if it does not light, power isnt getting to it, and this would indicate a fuse blown, or a wire broken or grounded.
Jan 29, 2010 at 10:45 AM
