Scanner shows code 301 cylinder 1 misfire detected, 456 with EVAP leak small detected, and 442 EVAP emission Control System purge small leak.
At start up engine RPM is normal for about 15 seconds then RPM drops, when I turn on the A/C the RPM's increase to normal. What do you think it could be spark plugs, oxygen sensor or something else. Also about a year ago the camshaft position sensor failed and was replaced.
May 27, 2008 at 9:46 AM
