2003 Dodge Durango Grinding Noise
BRTMOY7
Brakes problem
2003 Dodge Durango Four Wheel Drive Automatic
There is a constant grinding noise coming from the front passenger tire. We checked the brake pads, rotors and replaced the caliper. It is still grinding, while braking as well as while driving what else could cause this?
Jul 20, 2010 at 1:15 PM
BLACKOP555
  • 10,386 POSTS
may not be brakes. start checking for wheel bearing issues
Jul 20, 2010 at 4:58 PM
BRTMOY7
I have raised the vehicle and spun the tire as well as checked for any loosness. How else would I check the bearing to cause the grinding?
Jul 21, 2010 at 6:11 AM
BLACKOP555
  • 10,386 POSTS
wiggle the tire and look for play in the wheel on the spindle. if found there its wheel bearing. if its on the knuckle ball joints may be bad.
Jul 21, 2010 at 7:20 AM
