2003 Dodge Durango FUEL
BAMALODI
Engine Performance problem
2003 Dodge Durango V8 Four Wheel Drive Automatic
My Durango will only start after engaging and pressing the gas pedal. After it starts it will only stay running if I keep the RPMs above 2000 RPMs, if I let is try and idle it dies. It appears to me that it could be fuel related, maybe a filter? 2 questions:
Can you help diagnose the problem?
Can you direct me to where the filter is located?
Nov 26, 2009 at 4:12 PM
  • 75,988 POSTS
Clean and test the idle air control valve and test the throttle position sensor, the fuel filter is in the fuel tank
Nov 26, 2009 at 8:24 PM
