2003 Dodge Durango blower motor
48,000 MILES • V8 • 4WD • AUTOMATIC
SIGNMAN
my front blower motor does not work at all,i have bench tested the motor itself and it works fine.I thought it might be the resistor switch but wouldnt that make it work on one speed only. could it be the fan switch itself .i would appreciate your help.thank you
Jun 29, 2008 at 12:50 PM
MERLIN2021
  • 17,250 POSTS
Check to see if power is getting to the resistor, if yes, change it, if not check fuses and relay, and the speed switch.
Jun 29, 2008 at 1:00 PM
