2003 Dodge Durango air will not blow
95,000 MILES • V8 • 4WD • AUTOMATIC
STAYIN2OONED
the air in the front dash will not blow. it will get cold in the vents but the fan doesn't blow the air out. the air works because there is back vents that do blow so that fan does work. i tried to replace the fuse but a new fuse was not the problem because it still does not blow any air, cold nor hot.
Sep 13, 2009 at 10:20 AM
  • 75,988 POSTS
Could be the blower motor relay, blower motor resistor and motor itself
Sep 13, 2009 at 10:34 AM
