sometimes the durango feels like it slips into neutral around curves. Is this a sign the tranny is going or possibly something else?
Oct 14, 2009 at 5:33 AM
✓Experienced Mechanic
If it only happens around turns, make sure the trans fluid is full. Check it with the engine running, hot, and check the dipstick if it needs to be in park or neutral. I believe the Durango is neutral, but make sure. If it is low, make sure to refill it with the proper type (listed on dipstick). I BELIEVE the 02 takes ATF+4. Make sure!
