2002 Dodge Durango Passenger side carpet and pan gets wet?
2002 DODGE DURANGO
102,742 MILES • V8 • 4WD • AUTOMATIC
JOE2222
The passenger side carpet area has been getting wet, and it appears to be tied to the use of the air conditioning. I can't seem to tell where the water is coming from but it is significant, I have soaked up and vacuumed up a lot of it. The water is clean has no smell so I am guessing condensation.
Any ideas on where to look for and fix the leak?
Thanks,
Joe222
Jun 6, 2010 at 7:23 AM
BLACKOP555
  • 10,386 POSTS
you are goign to have to clean out the evaporator case drain. if its plugged up it will cause condensatioin to leak out of the case instead of going outside on the ground
Jun 6, 2010 at 10:39 AM
STPACO23
WHERE DO I FIND THE THE PLUG OR OPEN TO CLEAN THE DRAIN
Jun 11, 2010 at 1:59 AM
BLACKOP555
  • 10,386 POSTS
only proper way to clean out the evap case is to split the case apart and thats the hard part. you can try to ream ou tthe other one but th edirt will just collect back in the same spot again and plug up again
Jun 12, 2010 at 11:03 AM
