2002 Dodge Durango on acceleration is sounds like a diesel
63,000 MILES • V8 • 2WD • AUTOMATIC
BLACKDB
a few years back this started and only in the mornings on a cold day. I would start the engine and a roar that sounds like a diesel began. vehicle moved fine in reverse and drive, just was noisy and maybe a bit sluggish. after a minutes or so it would level out and sound normal and function normally.
Now it is more often, does not have to be a cold day or the initial morning start up. Does this sound like anything to you? and if a common thing is it something easily repaired.
thanks Don
Aug 26, 2010 at 6:34 AM
  • 110,248 POSTS
Don:
Does it sound like an industrial fan and get louder when the RPM's go up?
Sep 17, 2010 at 6:34 AM
SUMFUNNY
I wasn't the original poster but your description sounds exactly like my 2000 Dodge Durnago, what woud be a possible cause?
Nov 9, 2010 at 3:24 PM
  • 110,248 POSTS
engages when the vehicle's engine operfates a high temp or ar at time it starts a+S\t first start
Nov 10, 2010 at 5:40 AM
