2002 Dodge Durango oil pump
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
BRENDA FAYE
I have no oil pressure so I am fairly sure I need to replace my oil pump where can I find a diagram and instructions on how to change an oil pump on my car I want to do it myself
Dec 16, 2009 at 12:30 PM
CARADIODOC
  • 34,414 POSTS
How did you eliminate all the other possibilities and decide on the least likely cause? How did you determine you have no oil pressure? How long have you run the engine since you noticed a problem? Is the engine making rattling or knocking noises? Did you check the pressure with a mechanical gauge?
Dec 25, 2009 at 5:53 PM
