2002 Dodge Durango Ignition Locked
10,500 MILES • 6 CYL • 4WD • AUTOMATIC
CHITTLES MCGUMSEY
The ignition switch is locked. The key will not turn at all. This is after replacing the starter(which wasn't the problem) and then a new battery (was the problem) Also note, before new battery during an attempt to jump start it that would not charge, I had to put it in neutral and manually push the vehicle into the garage. The gear shifter and ignition switch worked then, but after installing the new battery...NOTHING. Can you please help?
I do know of the recall involving the transmission lever and linkage;column shift. Could that be it?
Thank you for any help you might offer.
Waiting Patiently.
Sep 24, 2009 at 5:56 PM
  • 110,248 POSTS
I'm sure the battery had nothing to do with this or the starter. Is the key presently jammed in the ignition? Can you move the shifter at all? Can you move the key at all?
Oct 1, 2009 at 12:31 PM
