Fuel filter
MOMOFFIVE
  • 2005 DODGE DURANGO
Engine Mechanical problem 6 cyl Two Wheel Drive Automatic 104789 miles
My engine light has came on and when I push on the accelerator it feels like it isn't getting gas. Where is the fuel filter located on this model?
Thursday, September 18th, 2008 AT 8:11 PM
2CARPRO JACK
  • 11,533 POSTS
There is a fuel filter on the frame rail on the drivers side. Here is a guide to help you get an idea on how to change it out.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
You should run the codes as well to see what code comes up so it will guide us to a possible problem.
Cheers, Ken
Saturday, November 24th, 2018 AT 11:57 AM
MOMOFFIVE
It is giving me a code for the throttle body?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,289 POSTS
This is common for the throttle actuator to go out. Here is a guide that will help you change it out and get back on the road.
https://www.2carpros.com/articles/how-a-throttle-body-works
Cheers, Ken
JABIRD2528
  • 2002 DODGE DURANGO
  • V8
  • 140,000 MILES
Where is the fuel filter on this vehicle?
Tuesday, June 23rd, 2020 AT 5:25 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
The fuel filter is part of the fuel pressure regulator on top of the tank here are diagrams below to show you how to change it and its location. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
MONEIL
  • 2003 DODGE DURANGO
  • V8
  • 4WD
  • 85,000 MILES
How to get to fuel filter on gas tank
The fuel filter/fuel pressure regulator (Fig. 3) is located at top of fuel pump module on top of fuel tank (Fig. 4).
Fuel pump module removal is not necessary for filter/regulator removal.
Drain fuel tank and remove tank. Refer to Fuel Tank Removal/Installation.
Clean area around filter/regulator to prevent contaminants from entering pump module.
The fuel filter/regulator is pressed into a rubber grommet. Remove by twisting and pulling straight up. CAUTION: Do not pull filter/regulator more than three inches from fuel pump module. Damage to coiled fuel tube (line) may result.
Fig. 5 Fuel Tube And Clamp - Typical
Gently cut old fuel tube (line) clamp (Fig. 5) taking care not to damage plastic fuel tube. Remove and discard old fuel tube clamp.
Remove plastic fuel tube from filter/regulator by gently pulling downward. Remove filter/regulator from fuel pump module.
DUMMY1
  • 2000 DODGE DURANGO
  • V8
  • 4WD
  • 43,000 MILES
How do I change my fuel filter and where is it located
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter/fuel pressure regulator is mounted on top of the fuel pump module, located on the top of the fuel tank. No periodic service is required. The fuel filter/fuel regulator should only be replaced if it is clogged or if a diagnostic procedure indicates it is time to do so. No separate frame mounted filter is used.
If you still need to replace the filter/regulator assembly, below are the procedures to do so.
REMOVAL:
Disconnect the negative battery cable.
Remove the fuel tank filler cap.
Properly relieve the fuel system pressure.
Raise and safely support the vehicle.
Remove the fuel tank assembly.
The fuel pressure filter/regulator assembly is located on the top of the fuel pump assembly. It is not necessary to remove the fuel pump to remove the pressure filter/regulator assembly. Matchmark the direction the hose fitting points. Unit must be reinstalled pointing in the same direction.
Twist the filter/regulator assembly out of its grommet on the fuel pump.
Remove the snap ring that retains the convoluted tube to the filter/regulator. Slide the tube down the plastic fuel tube to access the fuel tube clamp.
Gently cut the old fuel tube clamp off, taking care NOT to damage the fuel tube or drop the clamp inside the tank.
Remove the fuel tube from the filter/regulator assembly by gently pulling downward.
Remove the filter/regulator assembly from the fuel pump module.
INSTALLATION:
Install a new clamp over the plastic fuel tube.
Install the filter/regulator assembly to the fuel tube. Rotate the filter/regulator until it is pointed to line up with the matchmark previously made.
Tighten the clamp to fuel line using Hose Clamp Pliers C-4124 or equivalent.
Slide the convoluted plastic tube up to the bottom of the filter/regulator and install the snap ring.
Press the filter/regulator assembly into the rubber grommet making sure it is pointed in the 10 o'clock position.
Install the fuel tank.
Lower the vehicle.
Connect the negative battery cable.
Install the fuel filler cap.
Thanks for using 2CarPros. Com!
2CP-ARCHIVES
  • 4,540 POSTS
  • 83,000 MILES
I would like to know how to replace a fuel filter on a 2000 Dodge Durango.
Tuesday, June 23rd, 2020 AT 5:26 PM (Merged)
  • 109,867 POSTS
A combination fuel filter and fuel pressure regulator is used on all engines. It is located on the top of the fuel pump module and requires that the fuel tank be removed to access.
2. Drain and remove fuel tank.
3. Clean area around filter/regulator to prevent contaminants from pump module.
4. Remove or disconnect the following:
1. Fuel filter/regulator by twisting and pulling up CAUTION
2. Old fuel tube clamp by gently cutting clamp, taking care not to damage fuel tube
3. Plastic fuel tube from filter/regulator by gently pulling downward
4. Filter/regulator from fuel pump module
