2002 Dodge Durango check engine light on
95,300 MILES • V8 • 4WD • AUTOMATIC
I_LEEN
The check engine light is on & it wont pass smog. I took it to a shop & they came u[p with code:P0601 & said its the computer brain. What i want to know is do i have to take it to the dealer & pay $800.- 1000. or can i get a brain from a junk yard, does it then have to be programed by the dealer? What about (flashing) what is that & would it work? Any advice you have i would appriciate!!!! THANK-YOU VERY MUCH
Sep 4, 2010 at 9:43 PM
WRENCHTECH
  • 20,760 POSTS
Programming and flashing are the same thing. Yes, the PCM does have to be programmed before it can be used. I would never attempt to use a junkyard PCM. Not only are there a million different part numbers but I wouldn't want any electronics that have been sitting around exposed to weather as they have.
Sep 5, 2010 at 12:13 AM
