2002 Dodge Durango Brake Tail Light
MADISONPTHREE
Electrical problem
2002 Dodge Durango V8 Two Wheel Drive 170000 miles
Driver's side brake tail light does not work. Passenger side ok. Replaced socket - replaced bulb. All other tail lights appear to work fine.
Dec 20, 2008 at 4:06 AM
  • 110,251 POSTS
Hi:
You need to check for power to the socket. If it isn't there, you will need to use a test light and follow the wiring to see where the power is lost. I believe there is a plug on the driver's side. Make sure that isn't the problem.
Let me know what you find.
Dec 20, 2008 at 7:35 AM
