Blower speed?
157,000 MILES • V8 • 2WD • AUTOMATIC
WJV1
MY Ac only works on high and it blows very cold but it does not work on low or medium, what are some of the things i can check to keep from payng a Hugh AC repair bill.
Jul 8, 2009 at 12:33 AM
BUDDYCRAIGG
  • 2,262 POSTS
are you talking about the blower fan only works on high?
Jul 8, 2009 at 7:48 AM
WJV1
yes the switch that turns the air up higher it only blows in the high position.
Jul 8, 2009 at 2:06 PM
BUDDYCRAIGG
  • 2,262 POSTS
4 things it could be the problem
a fuse.
the blower motor relay
the blower motor resistors
the blower speed switch.
I emailed you a schematic,
it's a 99 full sized pickup, but i think it will be the same.
Jul 8, 2009 at 2:40 PM
AMEGILL
heater blower only works on high speed
Aug 8, 2020 at 3:56 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Check for power getting to the resistor, on the heater plenum, the resistor then plugs into the blower, if power is present, replace resistor, if no power, check fuse, and or switch...
