2002 Dodge Durango ABS Light
86,000 MILES • V8 • 4WD • AUTOMATIC
JACLARK51
My abs light is currently on and the shifter is stuck in park, and the steering wheel will not lock after the Durango is turned off. Do you have any idea what might be casuing this? I am able to release the shifter by pushing a lever under the rubber boot of the shifter.
Dec 24, 2008 at 7:23 AM
  • 110,248 POSTS
Hi:
Don't laugh, but are the brake lights working?
Dec 24, 2008 at 12:59 PM
JACLARK51
Yes the lights are working. I found a work around though. I just removed the rubber boot at the bottom of the shifter and pushed in the release mechanism. The lock pushes right in and the abs light eventually goes back off. It seems to only happen when it gets really cold, below freezing.
Jan 3, 2009 at 11:02 AM
