ABS and Brake light
KHAUTO
  • DODGE DURANGO
I have a 1998 Dodge Durango SLT, 5.2L engine. The ABS and the Brake Light are both on. It started intermitantly. Sometimes on sometimes off. I changed out the rear brake wheel cylinders. There was a little bit of a leak on one. Put the brakes back together and bled the brake lines. Now the ABS and Brake light are on all the time. There are no other symptons. Brake pedal feels firm when braking, no surging, seem to be able to brake adquately. Any suggestions?
Tuesday, February 20th, 2007 AT 1:33 PM
MOPARDADDY
  • 7 POSTS
I had a 1998 dodge 1500 that did the same thing abs light and brake light on.I took it to a friend that could read those codes from the computer, the basic code reader cant get them, it turned out to be a vehicle speed sensor in the rear differential aka pumpkin.I could only get the sensor from the dealer at that time. But it was an easy change out. Hope this helps
Tuesday, March 13th, 2007 AT 10:06 PM
