2002 Dodge Durango 4X4 switch
130,000 MILES • V8 • 4WD • AUTOMATIC
SZBIRDDOG
My Durango is stuck in four-wheel drive and will not release using the selector switch. Is there a way to bypass the switch to disengage it?
May 17, 2009 at 4:45 AM
  • 110,248 POSTS
The switch can't be bypassed. Chances are the actuator on the transfer case is the problem. Check to see if you are getting power to the actuator itself. If you are, that is most likely the problem.
May 18, 2009 at 11:57 AM
