It's usually gray, about an inch in diameter, and is always on the right, (passenger) side of the firewall right behind the engine. It comes forward from the firewall about two inches, then turns down for another two or three inches. The end hanging down isn't attached to anything.
The end of this round hose is formed into a flat slot to reduce entry of rain and bugs. Squeezing it will open it up hopefully allowing any trapped debris to fall out. The debris can build up further inside too. That's when you will need to remove the hose and poke around in the drain tube.
Caradiodoc
SPONSORED LINKS
Saturday, August 8th, 2020 AT 10:53 AM
(Merged)
