2002 Dodge Durango Low Roar at Speed
KENJEEPN
i have a 2002 dodge durango,i thought the noise sounded like tire noise.but that wasnt it,also replaced rotors and pads up front,gettinglow roar when i get to 35 to 40 mph,any suggestions
Mar 9, 2007 at 7:52 AM
BOOTDOG
  • 665 POSTS
check your wheel bearings. you can jack up the vehicle and shake the tire up and down for excessive play, or even pull the bearings out and visually inspect them. if they're ok then it's possible that the carrier bearings inside the differential or making the noise.
Mar 9, 2007 at 7:58 AM
VAMPYRICO
  • 27 POSTS
check to see if your splash guards are all where they need to be and arent contacting the tire at all. also make sure the tire isnt making contact with anything in the wheel wells. if the tires are new, it could be just that. some tires make annoying noises. may or may not be thecase but its possible.
Mar 9, 2007 at 1:03 PM
Suggested Repair
Check the wheel bearings for excessive play and inspect them if needed. If they are good, inspect the differential carrier bearings. Also confirm splash guards and wheel-well components are not contacting the tires.
Conversation Summary
The owner of a 2002 Dodge Durango reported a low roar at 35 to 40 mph after ruling out tire noise and replacing the front rotors and pads. One reply recommended checking the wheel bearings and, if they are fine, the differential carrier bearings. Another suggested checking splash guards and wheel-well clearance, noting that some tires can also make noise.
