2001 Dodge Durango Temperature guage reading
95,000 MILES • V8 • 4WD • AUTOMATIC
WORLDBYSEA
Should the temperature guage have a higher standard operating temperature when it is 100 degrees outside versus 75?
Thank you for your time.
Sincerely yours,
Larry
Jun 25, 2010 at 2:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the thermostat will open at its specified temp. to cool off the engine..if it is warmer outside then it will just heat up the engine quicker and cause the thermostat to open sooner. the engine temp. should still remain the same.
Jun 25, 2010 at 5:24 AM
