2001 Dodge Durango rear drum removal
104,000 MILES • V8 • 4WD • AUTOMATIC
CARDIACCATH0
I tried for the first time removing my rear brake drums on my durango without success. I tried loosening the tension screw from the back but I was still unable to remove the drum any ideas?
Jul 4, 2008 at 11:34 AM
MERLIN2021
  • 17,250 POSTS
Chrsler has in my opinion the worst drum brake setup going, if the adjuster lever is held with a pick you should be able to loosen the starwheel adjuster enough to pull the drum, if the screw isn't frozen.
If it's frozen, you need two large screwdrivers and pry it off...not easy!
Jul 4, 2008 at 11:41 AM
