2001 Dodge Durango Power Window-rear passenger stopped work
134,000 MILES • V8 • 4WD • AUTOMATIC
GOT_EM_ON
rear passenger power window stopped working and is stuck in down position. It does not work from the switch on its door or from the main switch on the drivers door.
When I press the switch on the drivers door I can see the light blink off on the switch on the rear passenger door, but nothing happens-do not hear motor attempting to work etc..
I seem to be having serval issues over the past 6 months-replaced clock spring in steering wheel, drivers side heated seat no longer works, radio made severe electrical static which I just replaced last weekend and now the problem with window.
Thanks in advance for the help
Apr 18, 2008 at 1:30 PM
MASTERTECHTIM
  • 4,750 POSTS
most likely its a faulty window motor. to check you need to remove the door panel and check for power and ground at the window motor, if its good then you have to replace the motor.
Apr 18, 2008 at 1:34 PM
