2001 Dodge Durango LEEK
DURANGUENZE
Engine Cooling problem
2001 Dodge Durango 6 cyl Four Wheel Drive Automatic
THOUGHT IT WAS THE THERMOSTAT, BUT THE THING THAT HOLDS IT... IS LEEKING, DO I HAVE TO REPLACE THAT ENTIRE PIECE OR CAN I SEAL IT?
Jan 22, 2010 at 8:41 AM
CARADIODOC
  • 34,403 POSTS
Is it cracked? If not, replace the gasket. Be sure to clean off all the old gasket or it will leak again. If not perfectly clean, chunks of gasket stuck under the housing will cause the housing to crack when the bolts are tightened down.
caradiodoc
Jan 23, 2010 at 12:08 AM
