low engine idle?
98,000 MILES • V8 • 4WD • AUTOMATIC
FIXITALL
when I start my car (engine is cool) the idle runs high, once I press on the gas it seams to idle down but every now and again it will idle back up, for instance to and from the grocery. only noticable when stopped at a light or first starting. It will occasionally rev up and down on its own at a stop light. dealer cant find anything wrong????
Mar 29, 2009 at 12:35 PM
  • 75,988 POSTS
It sound sliek the throttle bore is dirty and needs service here is a guide to help you fix the problem also lets check for vacuum leaks.
https://www.2carpros.com/articles/idle-air-control-valve-service
and
and
Mar 29, 2009 at 8:03 PM
JUDY007
  • 0 POST
I found a missing vacuum hose once I replaced it the engine runs great !
Oct 5, 2020 at 3:47 AM
