blower motor not working?
170,000 MILES • V8 • 4WD • AUTOMATIC
MHB
front blower quit ? I have checked both fuses for the air conditioner and they are both good ?
May 29, 2010 at 5:23 AM
We need to check a couple things in order to figure this out. Here is a guide that will get us started:
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
We need to check power at the blower. If you have power, then I suspect the motor is the issue. Jump 12 volts to the motor and see if it comes on.
If it does then we need to check the resistor shown in the wiring diagram.
If the blower motor does not come on when you jump power to it then the motor is the issue. Here is a guide that will help with that:
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
Run through all this material and let me know what questions you have. Thanks
Dec 10, 2020 at 4:43 AM
