2001 Dodge Durango Engine overheating
2001 DODGE DURANGO
165,000 MILES • V8 • 2WD • AUTOMATIC
JOESNUFFY180
I resently replaced the thermostate and flushed the radiator. I did this about a month ago. It strated overheating again. When I turn the heat on, it blows cold air. It will start to overflow radiator fluid from the overflow tank and steam alot. Any help would be appriciated.
Dec 8, 2009 at 10:22 PM
CHARLESGREENWALT
[quote:b391f7b356="joesnuffy180"]Engine Cooling problem
2001 Dodge Durango V8 Two Wheel Drive Automatic 165000 miles
I resently replaced the thermostate and flushed the radiator. I did this about a month ago. It strated overheating again. When I turn the heat on, it blows cold air. It will start to overflow radiator fluid from the overflow tank and steam alot. Any help would be appriciated.[/quote:b391f7b356]its your water pump
Dec 19, 2009 at 9:30 PM
