2001 Dodge Durango Engine codes
99,000 MILES • V8 • 2WD • AUTOMATIC
FRANKIEFUEGO
  • 18 POSTS
I took my Durango to Autozone and the ran the check engine light test. It gave me a P0601 Internal Control Module Memory Check Sum Error. What should I do to remedy that problem?
Dec 25, 2007 at 5:18 AM
BMRFIXIT
  • 19,053 POSTS
[quote:62fe8d1181="frankiefuego"]Engine problem
2001 Dodge Durango V8 Two Wheel Drive Automatic 99000 miles
I took my Durango to Autozone and the ran the check engine light test. It gave me a P0601 Internal Control Module Memory Check Sum Error. What should I do to remedy that problem?[/quote:62fe8d1181]
CLEAR CODES
start truck if code return
need power control module
have it done at a dealer because new one have to be programed to the truck!!
good luck
Dec 25, 2007 at 11:48 AM
FRANKIEFUEGO
  • 18 POSTS
It stays on every time I start it.
Dec 25, 2007 at 1:57 PM
BMRFIXIT
  • 19,053 POSTS
[quote:21e8fadef5="frankiefuego"]It stays on every time I start it.[/quote:21e8fadef5]
power control module no good
Dec 26, 2007 at 9:15 AM
