2001 Dodge Durango Check Engine Light Code
233,000 MILES • V8 • 2WD • AUTOMATIC
GRISELSEGARRA
Took my durango in to an auto part store and put it on the diagnostic computer. It came back with a PO601 Intake Control Mod Error. What is this? and what is the PCM? Is this something I can fix with replacing a sensor?
Apr 29, 2010 at 11:04 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you what is your engine size n liter
Have you tried resetting the light….then seeing if it comes back?
If so……how many times?
Apr 29, 2010 at 1:06 PM
GRISELSEGARRA
2001 Dodge Durango V8 Two Wheel Drive Automatic 233000 miles
we have reset the check engine light at least 6 times and it still comes back
Apr 29, 2010 at 1:31 PM
IMPALASS
  • 3,112 POSTS
Hello –
I was doing a follow up. I had not heard back from you in some time and wanted to make sure you had your question answered. Is your car fixed?
I was contacted by the 2CarPro staff and you sent the post back to me. I truly apologize that I have not responded to you. I seem to be experiencing technical difficulty.
Did you get your answer or do I still need to assist you?
May 9, 2010 at 1:48 PM
  • 75,988 POSTS
P0601* PCM Internal Controller Failure-The PCm is the Powertrain Control Module which means also the computer. double check the computer wiring connectors -Won't clear try reflashing the computer and see what happens if it continues could very well be a computer problem
May 10, 2010 at 4:55 PM
