2000 Dodge Durango Won't start
100,000 MILES • V8 • 4WD • AUTOMATIC
CCCARTER69
I have replaced the starter, checked the relays, and my durango will not start. The battery is fine as well. When I turn the key, the lights and radio come on, but there is nothing cranking. There is a small click sometimes, but for the most part it does nothing. It would do this intermittingly in the past but now it is nothing. In the past we would take out the relays and put them back, or move the gear shift up and down and that would work sometimes, but not now. What else could be wrong?
Jan 2, 2010 at 1:47 PM
  • 75,988 POSTS
No crank:
Your possibilites here could be the starter, starter relay, transmission range switch, ignition switch
Dec 31, 2018 at 5:30 AM
MICHAEL1969
I have had lots of luck repairing or replacing the starter.Starter repair involves two pole shoes and a plunger for the starter solenoid.
