2000 Dodge Durango Turn Signals
2000 DODGE DURANGO
10,000 MILES • V8 • 4WD • AUTOMATIC
SUPERSHOPPER1981
My boyfriends 2000 Dodge Durango turning lights went out. His hazards are working normally, along with his brake lights. I heard it may not be a relay because the hazards are working properly. What do you think? Thanks\r\n
Angela
Aug 25, 2009 at 11:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle uses a combination flasher. this means if the hazard lamps are working and the turn signals are not, the flasher is not at fault. in this case, suspect a faulty multi-function (turn signal) switch.
Aug 25, 2009 at 4:01 PM
