2000 Dodge Durango Turn Signal Flasher
121,000 MILES • V8 • 4WD • AUTOMATIC
GRIFFINB1
The turn signals are not working on either side. It started as an intermittent and progressed to not working at all. The 4-way flashers work fine. I purchased a new flasher but don't know where the original flasher is located. Is the turn signal flasher part of the 4-way flasher? What is R & R procedure?
Apr 28, 2010 at 4:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle does use a combination flasher for both and it is located on the relay / fuse block (behind left side of dash, attached to junction block). most likely cause of failed signals is a faulty turn signal (multi function) switch.
Mar 6, 2021 at 3:57 AM
