2000 Dodge Durango thermostat
92,000 MILES • V8 • 4WD • AUTOMATIC
WHITEBOY77
what makes the dodge durango overheat
Apr 21, 2010 at 12:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
many things can cause an engine to overheat..
first check coolant level to ensure its full. if coolant is low check for leaks. if OK , inspect the radiator fan(s) to ensure they are coming on. if OK as well then may need to remove thermostat to test it , ensure it is opening properly .
Sep 7, 2020 at 4:52 AM
