many things can cause an engine to overheat..
first check coolant level to ensure its full. if coolant is low check for leaks. if OK , inspect the radiator fan(s) to ensure they are coming on. if OK as well then may need to remove thermostat to test it , ensure it is opening properly .
Sep 7, 2020 at 4:52 AM
