2000 Dodge Durango shifting out of second
130,000 MILES • V8 • AWD • AUTOMATIC
JOESDEAD2
1. what transmission do i have ?
2.the trans would slip in and out of gear.
3.sometimes not shift into 3rd or silip out of second on a hill and also any other gear.
3. i have adjusted the front and rear bands and the tv cable. it now will not shift at all out of second gear
72 inch pounds on front and rear 3/16 inch play in cable wich is stock position.
4. possibly not have right fluid in it used non atf-4 fluid to bring to levels back after adjusting rear bands
Jul 17, 2010 at 3:35 PM
  • 110,246 POSTS
A small amount of atf won't cause this to happen. Has the check engine light come on? To me it sounds like a TCM problem, but I need to know if the light came on or if you had it scanned.
Aug 4, 2010 at 1:39 PM
