Neutral Safety Switch
MICKKK
Where is the neutral safety switch located on the transmission. I understand that due to the bad neutral safety switch the Durango does not start when in Park and the gears slip. Thanks in advance
Mar 29, 2008 at 1:24 PM
MASTERTECHTIM
  • 4,750 POSTS
right where the shifter linkage is on the transmission. the thing that has a bunch of wires going to it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Mar 29, 2008 at 1:26 PM
SWEETDREAMEROF08
I had to replace the transmission in my 2001 dodge durango bought a used transmission at a salvage yard it was out of a 2000 dodge durango the neutral safety switch is different, is there an adapter?
Jul 29, 2019 at 7:54 AM (Merged)
FIXITMR
  • 9,989 POSTS
so did they tell you it was supposed to fit/work? go get your old NSS back and try it?
SWEETDREAMEROF08
yes they told us that it would fit... we have the old NSS but it doesn't fit. it has a 1in. mount and the hole is a 3/4 in. i need to know if there is an adaptor for the wiring or if i can buy a new NSS that will mount to the 3/4 in. hole (and if so does it have the wire labels)
