2000 Dodge Durango ENGINE LIGHT ON
125,000 MILES • V8 • 2WD • AUTOMATIC
SHELLHEAD8
wHAT COULD BE CAUSING MY CHECK ENGINE LIGHT TO COME ON
Jun 4, 2008 at 1:26 PM
BMRFIXIT
  • 19,053 POSTS
A lot of things
loose and or bad gas cap
you have to check for codes to pin point troubled area
most local parts stores and local repair shops will scan it for free
or you can cycle the ignition key three times on off
ending with key on
that should get you the codes
in the odometer area P# # # #
and you posted here for more help
Jun 4, 2008 at 1:56 PM
